[5th Gen : 08+]: Change oil every 10,000 miles?
Personally, I like to keep my engine as clean as possible while not letting dollars just fall out of my pocket, so I try to change my full synthetic before 3K miles. My thinking is that at 3K, the oil is dark, has changed appearance, and after an oil change, there is a noticable change in engine response related to the gas pedal. If my engine can notice a change, then fresh oil is much better than 3K oil. Furthermore, I don't want dirty oil circulating through the PCV system, accumulating in the intake area, and I would like to keep my critical engine parts, bearings, roller-rockers, timing components, etc lubed with fresher oil, and no matter how good the oil is dirt still gets into the engine to some degree. Plus, changing the oil gives me the opportunity to look under the vehicle, and inspect other components. Considering how painful it is to hear ticking noises from my engine (roller rockers on two separate occasions), even under my oil change regimen, I don't like the thought of "pushing" my oil at the expense of my engine and its tight tolerance components, and oil pressure sensitive components. 10K would keep me up at night.
I use Quaker State Ultimate full synthetic with Fram XG or K&N oil filter (whichever I can find the day I'm changing oil). I change at 5000 miles and the oil is still transparent. You could go 15,000 miles on a full synthetic oil as long as your filter was up to the task. If you buy a filter that claims 20,000 miles like the $15 Fram at Walmart (can't remember the name of it) you could do so. That said I'm under warranty and like round numbers so I do every 5000 miles because I change my oil and it costs about $25 for oil and filter so why not. Also I drive 5000 miles about every 6 weeks.
I've used Castrol Edge Full Synthetic 5w-20 since day one in 2013 SXT oil change done at every oil change indicator warning with a purolator or wix filter it has 199586 km as of today never had any engine related issues over the 6 years of ownership. No rocker arm ticking, no cam lob wear, no oil leaks it run just as smooth and quietly as it did on the first day. I did replace the oil by pass valve it broke during an oil change luckily I had one in the glove compartment in the van so when the technician told the bad news I just told him I had a Dorman replacement just put it in. Today oil are better refined gasoline is cleaner less gunk and carbon in engine with governement regulations I do my oil change by the book. Oil Change Indicator Warning come on usually around 12250 -12900 km highest it ever went (7500-8000) miles
Correct. Here are the instructions do the reset:
1. Turn the ignition switch to the ON/RUN position (do not start the engine).
2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps.
The following users liked this post:
HighSierra (10-22-2019)
Regarding that bypass valve; my suspicion is that the person removing the used filter from the housing is tilting the filter too far in order to avoid the intake air tube, thus severing the valve. Quick lubes seem to be in a hurry. The Doorman presentation of their bypass valve said the vales fail due to excessive dirt and debris causing wear, then failure. I disagree.
teets.18 (10-23-2019)
Since the plastic nipple is under spring tension they usually shoot out like a rocket there's the possibility a small piece or two might be left behind in the housing but upon inspection they can be easily remove with long nose pliers.
