[General]: Battery light
Im no expert on newer vehicles, especially when everything is controlled by computers, but have you checked all the fuses to make sure none are blown? There may also be fusible links along the charging system. They're fairly easy to spot; look for charred/burned wires leading from the alternator or battery. Good luck
check voltage. battery should not be less than 12.5v off and I think when vehicle runs 14.5 or 13.5volts.. if it is and the battery was replaced new. I suspect you have a alternator issue. most times battery dies because alternator stops charging it and then the vehicle draws the power from the battery. easy to do to take the alternator and battery and they can check it on bench at parts store.
