[4th Gen : 01-07]: 02 caravan electrical issues
wipers, blower, radio, power door locks , work until you turn key to start then everything works intermittent ,sometimes takes a couple minutes to come on ,then hear relay cycling on and of erratically, put van in reverse everything usually works, put in drive symptoms come back, noticed headlights flick a little and recently speedometer went from 0 to 100 the back ,and all gear selector symbols had square boxes around them ?
checked and cleaned ipm and fuses , when checking I put test light on negative and pin #86 of (I think start relay, removed) everything seems to work?? need help !!
Wouldn't bad / corroded cable or battery cause van to shut off or not run right? I do get a p1684 battery code
12vdc at pin 86 of the start relay indicates voltage is passing from the ignition switch through the TRS and TCM and on to the relay.
TRS = Transmission Range sensor
TCM = Transmission Control Module
