[General]: Guages Don't Work
> Hold the trip and reset ***** in then turn the key to on/run. Within a few seconds you should see the cluster start a self test. Let go of the *****. If everything moves the cluster is good and you know it's getting power.
> Smack the dash above the cluster. Anything come alive. In any case you probably have one of the most common problems on a 3rd generation van - cracked solder joints on the instrument cluster circuit board. Here's how to fix it:
