jolong
Old 04-28-2015, 09:10 PM
jolong2's Avatar
jolong2
jolong2 is offline
Unhappy jolong
I have a 98 caravan with no power to the AC clutch not sure where to start. Thank You
Old 04-28-2015, 10:27 PM
jkeaton is offline
Dodge Forum Administrator
Welcome to df. I'll move this to the correct section. How are you verifying you have no power to the clutch? Have you checked the fuses and is the system charged correctly?
Old 04-29-2015, 12:54 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Agree, Check the fuses first and maybe by-pass the high pressure switch.
Old 04-29-2015, 07:44 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Easiest place to start is as MT stated - check the fuse. That would be 15 amp fuse 11. Next pull the A/C clutch relay and jump contacts 30 and 87 at the relay socket. The clutch should engage immediately. If that works swap the relay with another identical relay on the panel. Still dead? Come on back.
