[3rd Gen : 96-00]: 1998 grand caravan transmission compatibility
Old 04-28-2015, 10:43 PM
Neon_Moon's Avatar
Neon_Moon
Neon_Moon is offline
Default 1998 grand caravan transmission compatibility
i have a 98 grand caravan that needs a transmission. what years will work? thanks!
Old 04-29-2015, 12:33 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
What size engine do you have in the vehicle?
Old 04-29-2015, 09:16 AM
Neon_Moon's Avatar
Neon_Moon
it has the 3.3
Old 04-29-2015, 11:47 PM
master tech
Any 41TE transmission from a 3.3 engine from the years 1997 thru 2002. But you can also use a transmission from a 3.8 engine too, But you need to match up the flex plate to the torque converter and look at the pins on the TRS( transmission range sensor) Because the early TRS had flat blades and the new ones has round pins. That's goes the same with the transmissions from a 3.3 engines.
Quick Reply: [3rd Gen : 96-00]: 1998 grand caravan transmission compatibility
