[General]: 2008 Dodge minivan front blower motor
"in every place the blower motor and the blower motor resistor and I slid the same problem". Does that mean you replaced the blower motor and blower resistor and you still had the same problem?
If that's true then as Master Tech stated you could have a bad control panel. You could also have a bad TIPM or connection at the TIPM (fuse box). It controls the ground to the motor.
