[5th Gen : 08+]: No rear heat ac controls
Old 09-10-2015, 04:06 PM
dclarke396's Avatar
dclarke396
dclarke396 is offline
Default No rear heat ac controls
we have a 2010 for about a year now, the front heat and ac work as normal but there is no power at the rear center console controls. I checked the fuses and they are in tact. how do you remove the heater control from the center console to troubleshoot it ?
Old 09-10-2015, 07:31 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Rear fan won't blow correct? Have you jumped or swapped the relay?
Old 09-10-2015, 09:58 PM
dclarke396's Avatar
dclarke396
i have not, i dont know how to jump the relay, i assume that bypasses it?
Old 09-12-2015, 05:01 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Yes. Remove the rear blower relay. On the bottom of the relay you'll see the contact ID numbers. Find 30 and 87. Correlate those contacts to the socket on the panel. Take a short length of wire and connect the two contacts on the panel. No need to turn the key on.
Old 09-12-2015, 01:10 PM
dclarke396's Avatar
dclarke396
no luck jumping that relay still no fan speed operation, i do hear a faint sound around the rear access panel like a solenoid click but thats it
Old 09-12-2015, 05:06 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Chances are you have a toasted blower motor or controller or wiring problem. I would access the motor connector and see if there's power and ground there. If you see it there the motor is toast.
BTW - Do you have auto temp controls and did you turn the key to on/run? Sure the fuse is good? I'm showing 20 amp fuse J15 on a diagram for an 08.
Old 09-13-2015, 09:28 AM
dclarke396's Avatar
dclarke396
thanks again, it has the basic duel zone dial controls up front, i tried it key on and key off no fan operation either way, fuse is good. I assume there is a rear blower motor somewhere in that right rear access panel?
Old 09-13-2015, 09:29 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Yes in the passenger side rear.
Old 09-14-2015, 01:56 PM
crxmanpat's Avatar
crxmanpat
crxmanpat is offline
dclarke,
This video, although being the procedure to replace the expansion valve, will show you how to get to your blower motor and resistor. Watch through 12:15 to see how to get to it (but DON'T unhook the lines in the wheel well), then skip to 16:00 to see where the resistor and blower motor are and how to remove.
Old 09-14-2015, 06:16 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Great video. Thanks for posting it. The vid showed a blower resistor. Any idea if a blower controller (for auto temp) would be in the same location?
Quick Reply: [5th Gen : 08+]: No rear heat ac controls
