[4th Gen : 01-07]: Sounds when turning of the steering wheel.
I just replaced the power steering reservoir and the power steering fluid (by disconnecting the 2 hoses to the small radiator under the van).
The part was $15 (free shipping) from ebay. Cut the old reservoir and found the fine filter to be clogged up 95%. No more whining sounds when steering at low speed.
Also inspected the CV joints and found a broken booth on the right side.
I will have to address that problem soon.
Trending Topics
When you do "short runs" the PS fluid will still be in the system plus you can damage the PS pump. When you drain the fluid from the lowest point all fluid gets out of the system.
OK, for only $65 I got a new right hand side CV joint. When inspected, the seal to the transmission was leaking. Replaced both and no more trans. fluid leaks. Thanks all.
