'96 Caravan headlamp replacement
RE: '96 Caravan headlamp replacement
Under the hood and the rear side of the headlamp assemblies, you will find a fairly large 3 wire connector. Unplug that, and twist the black lock ring off and remove the bulb. Easy as that, the driver side is a little bit more tricky as the battery is right there. When installing the new bulb, do not touch the glass part of the bulb, the glass could explode when you turn the lights on.
