[2nd Gen : 91-95]: Transmission leak
Do you know for sure it's coming from the solenoid?
I have had them leak from the o-ring on the dipstick tube, which will make it look like the solenoid is leaking.
https://www.google.com/webhp?sourcei...asket&tbm=shop
Regardless, a quick search brings up Solenoid gaskets for about $6.
Solenoid is on the front of the trans, under the airbox. The dipstick tube goes into the trans right behind the solenoid pack.
How sure are you you have the 4 speed trans? To my knowledge they dropped it from the 3.0 after 93. If you have mechanical linkage going from your throttle body to the trans, you have the 3 speed trans, which has no solenoid pack.
Trending Topics
hi there Brandon i ran my van for 25 minutes today and as i was underneath it nothing was leaking even after i shut it off nothing it seems it only happening after i drive my van tomorrow i will check again.
I have other question to ask you does the resistor on the left side of the fire wall does that control your fan speed for some reason my fan only works on high.i sent you the diagram and a picture i just curious is that the part that control you low medium and high on you r fan thanks for your help in this matter michael
