97 Caravan.. Backup light out..Bulbs and fuse OK, any suggestions
Hi all:
I have a 1997 Dodge caravan, it has served us well with very few problems..
My inspection expires soon and the Backup light/ 'Reverse' light isnt working.
I got new bulbs and have checked/swaped the 10 amp fuse with no luck.
Can you guys suggest what else I can check.
Thank you
Kam
Thank you
Kam
RE: 97 Caravan.. Backup light out..Bulbs and fuse OK, any suggestions
Could be the body control module (turns the lights on if you have the 4 speed transmission), otherwise its the switch on the front of the transmission that is causing the problem (3 speed models). That switch is called the park/neutral switch, and it is just above the transmission oil pan, has a 3 wire connector on it.
