odometer light stays on
Old 11-25-2005, 12:48 AM
426mopar's Avatar
426mopar
426mopar is offline
Default odometer light stays on
1998 caravan odometer light will not go off unless i unhook the batt ,, but once the key is turned on the light again will not go out and this inturn drains the batt. any suggestions???
I sure could use some help ..THANKS..
Old 11-26-2005, 02:57 AM
brandoncrone's Avatar
brandoncrone
brandoncrone is offline
Default RE: odometer light stays on
Do you have any aftermarket accessories installed???
Old 11-26-2005, 11:47 AM
426mopar's Avatar
426mopar
426mopar is offline
no
Old 11-28-2005, 09:32 PM
brandoncrone
Could be either a bad cluster, or maybe the ignition switch is bad. Try unhooking the ignition switch connector.
Quick Reply: odometer light stays on
