Wheel / Tire Size Question
Old 12-01-2005, 02:11 PM
Rawyzf's Avatar
Rawyzf
Rawyzf is offline
Default Wheel / Tire Size Question
I have a 97 Dodge Grand Caravan SE.
I did a little research and see the OE Size for the rim is 15x6 with a 5x114.3 bolt pattern. What is the OE Tire size?
Also, do you know if 16x6 with a 114.3 bolt pattern and 205/5516 HR will fit?
Those are my winter tires from my car that I am now storing and want to know if I can make use of them?
Thanks!
-Ryan
Old 12-01-2005, 07:58 PM
pgcruz's Avatar
pgcruz
pgcruz is offline
Default RE: Wheel / Tire Size Question
I have a 2005 and am running 16x7.5 114.3 with 235/60/16 tires with no problems. OE Tire size is 215/70/15.
The winter tires will fit, you will have a bigger gap between tires and fender though.
Old 12-01-2005, 11:51 PM
brandoncrone's Avatar
brandoncrone
brandoncrone is offline
ORIGINAL: pgcruz
Actually the OE tire size is 215/65/15, the 70 series started in 2001. You could use them but your speedo is going to be way off, approx 4.3% faster readout on your speedo than you are actually going. 215/60/16 is the alternate OE tire size.
Quick Reply: Wheel / Tire Size Question
