DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 01-09-2006, 01:56 PM
greaseangel greaseangel is offline
Default Check engine light trouble code
Ok, I just had the water pump and timing belt replaced on my 97 Caravan 3.0. Everything was running just fine, until the other day when I got stuck sitting on the highway while they were tearing up the road. Suddenly, while idling, the engine ran very rough for a momet, then the service engine soon light came on, and it returned to idling normally. This morning, I stopped by Auto Zone to ask them to pull the codes. It came back P0401 "PCM has determined that there is insufficient flow in the exhaust gas recirculation system." Where do I even start looking to determine the problem?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-11-2006, 06:01 AM
Chump Chump is offline
Vehicle: 1977 W200 Powerwagon
Default RE: Check engine light trouble code
Look around the EGR valve and the area that the mechanics were working in for loose wire connectors or vacuum hoses. The computer uses the oxygen sensor to check the EGR function, if it does not see the correct change in the exhaust it's sensing it will post an error code.
__________________
77 W200 440/727/NP203/4.10 All Stock
Old 01-19-2006, 01:27 PM
Junior5290 Junior5290 is offline
Its pretty common to have egr faults on the RS platform. They seem to fill with carbon and stop working. and the only cure was to replace it.
__________________
Don't worry about anything, nothings going to go right anyways
Old 01-22-2006, 01:43 AM
brandoncrone brandoncrone is offline
A 97 is a NS body van.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
Old 01-22-2006, 01:49 AM
1998dodge 1998dodge is offline
check your fuel filter and or fuel pump.
Old 01-22-2006, 01:52 AM
check your fuel filters and or fuel pump, catalytic converter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
