RE: keys will not workm
Is it parked on a hill? If it's on an incline, the key will be quite hard to turn, but will work if you give a little more pressure. Don't turn it too hard or you might bend the key. Another thought is if the key has an anti-theft chip in it, it might not work properly. In my experience, that only applies once the ignition has been turned on. If the key doesn't carry the proper codes in it, then it turns the vehicle off. If all else fails, you may have to get it checked out at the dealership.
__________________
there's a good chance that the above post contains a link
