DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 01-29-2006, 08:28 PM
r0de0 r0de0 is offline
Default 99 Caravan P-side P/W kapute
Howdy,
My Passenger side Power Window is open about 2 " as I left it.
Now when I try to close it, nothing.
The D side windows works fine.
Neither D or P side switches work so it may not be fuse.
I have a Hayes manual, not much help, and owners manual, about the same. The both mention that it is controlled by some sort of a Control Module and should be dealer serviced.
So, my question is: Which module and where?
I notice that under the hood in the Power Control Panel, there are several Relays and Modules that look the same.
I am assuming I could switch them around to see which is failing? I have tried reseating all the fuses, relays and modules, but to no avail.
It is a cold day in Canada to be driving around with my window open, could some one please give me technical details on how to troubleshoot or which module to swap-out?
I am an electronic technician and am not afraid to get involved with the wiring.
Regards, Wyatt.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-31-2006, 11:13 AM
brandoncrone brandoncrone is offline
Default RE: 99 Caravan P-side P/W kapute
There is no module, the windows get their power straight from a ptc in the fuse block under the dash. Its either on of the switches or the window motor itself. Sometimes if you keep trying the switch you can get it to work again, or if it is the motor, bang on the door panel in the center while pressing the switch to see if the motor will work enough to get the window closed.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
Old 01-31-2006, 11:11 PM
Default Cold Case Solved! RE: 99 Caravan P-side P/W kapute
Amazing, Thanks BrandonChrone!
I banged on the door panel in the center while pressing the switch, as you suggested, and it worked!
Now I will take the door skin off on a nicer day and find the fauly wire or motor...
Regards from Collingwood, Canada.
Wyatt.
Old 09-04-2006, 03:58 AM
99GrCaravanSE 99GrCaravanSE is offline
Default RE: Cold Case Solved! RE: 99 Caravan P-side P/W kapute
Hi,
Did you ever take the door skin off? I have the same problem and got all the screws and the clips off as per the Chilton Manual. The panel will lift off at the end but not the front. I didn't want to force and break it because there may be a screw hidden in the door lever somewhere. Any idea?
Also, was your regulator or the motor bad?
Thanks,
Tony
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
