DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-10-2006, 02:58 AM
HT HT is offline
Default Caravan shuts down by itself on the road
My 1997 Grand Caravan 3.8L AWD would just shut down sometimes by itself when I'm driving on the road. I'll pull over and try and start it and it cranks and cranks and cranks but it won't start up. I have to wait like 5-10 minutes then try again and it'll start up and run fine again for awhile and die again randomly when ever within a day or 2.
HELP!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-10-2006, 02:13 PM
chopper chopper is offline
Default RE: Caravan shuts down by itself on the road
One thing it could be is a computer problem.The heat causes the metal conductors to expand and break a connection somehow.If you can get it to do this and have a full diagnostic ran on the vehicle you might find out exactly what it is.Other than that you could just replace the expensive computer and hope for the best.
Another cheaper thing is a bad sensor.It could be any one of several so you would probably be better off to take it in to have any codes read.
__________________
92 Dodge Caravan 3.3 07 TC 3.8, 04 Mustang GT three Harleys and an airplane.Buy American!!!
Old 02-11-2006, 04:05 AM
stantheman stantheman is offline
had a newer one in the shop the other day with the same prob. his finally quit starting all together. ordered a new comp and it fired right up.
Old 02-15-2006, 04:35 AM
Chump Chump is offline
Vehicle: 1977 W200 Powerwagon
Have it scanned for error codes.
__________________
77 W200 440/727/NP203/4.10 All Stock
Old 02-23-2006, 08:33 PM
HT HT is offline
bump for more input
Old 02-24-2006, 11:32 AM
brandoncrone brandoncrone is offline
Could be a camshaft or crankshaft positon sensor. Very common problem and they usually have the same symptoms as you are having. If you cycle the key from off to on 3 times, ending in the on position the check engine should flash out some codes for you. Sometimes that doesn't work though, and you have to cycle the key like that within 5 seconds.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
Old 02-24-2006, 01:51 PM
ASH ASH is offline
Some auto parts stores like Auto Zone have scan tools and will check for error codes for free. Even if your check engine light isn't on, there may be some error codes that have been set. Mechanical issues are harder to track down, so that is why you are getting the advice to check the computer.
__________________
99 Ram 1500 SLT, 4X4, Quad, Long Bed, 5.9L, 3.5 Rears, 46RE w/Shift Kit, Self-ported TB, 180 T-stat, Hypertech PPIII, 14" x 3" round air cleaner, modded TPS-CKP sensors, 100K Mi
2005 Grand Caravan Special Edition, 45K Mi.
1991 Dodge Spirit, 2.5L 190K
Old 02-27-2006, 01:24 AM
petras petras is offline
i have a 96 gc with a 3.8 with a history of pcm problems, every 50k mi., i need to replace it, mechanics can't find an underlying cause for the pcm going bad that soon, only difference with my experience was that i couldn't restart and had to have van towed..reman. pcms going for around 350, used for around $200, good luck with yours
Old 02-27-2006, 01:27 AM
regarding bad pcms, i just replaced a bad pcm with a used one instead of getting a rebuilt, now i'm wondering if that was a mistake in the long run...do these pcms wear out or do other underlying causes make them eventually go bad? thanks, pete
Old 02-27-2006, 05:05 PM
studdly studdly is offline
try changing the fuel filter... I was having the same problem in my 91 with the 3.0 liter. I just changed the filter and it ran fine after that.......
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
