RE: 2001 Grand Caravan Sport Bad Resistor Block
when they burn out fast like that it is usually a motor problem and I've seen these motor problems usually being caused by moisture in the blower housing. If you pull the motor and find moisture problems, you need to make sure the drain tubes from the upper cowling are clean. Sometimes these tubes block and cause water to come in the fresh air intake. gl
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
