DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-17-2006, 02:13 PM
Rawyzf Rawyzf is offline
Default HELP!!! 97 Dodge Grand Caraven SE Problem
I am not really sure now to explain this...
When going around 45-55 the van kind of sputter and shifts between 3rd and 4th...or whatever gear it is in. If I get up to 60 and hold the gas steady, it is fine. Once I get to 65-70, then it starts to sputter again.
I don't know if this is a Tranny Issue, or a Engine Issue?
The Check Engine light is not on, nor is the Tranny light. The Check Engine light has been on in the past, but it goes off every once and a while, and this happens to be one of those times.
It did this once last week, so I had the dealer change the Tranny fluid and filter and fill her up with ATF4.
Any ideas? Anything I could try to change on my own for a low cost fix before bringing it to the dealership?
1997 Dodge Grand Caravan SE
3.0 v6
125,xxx miles.
Thanks
Ryan
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-17-2006, 05:42 PM
highrevr/tflea highrevr/tflea is offline
Default RE: HELP!!! 97 Dodge Grand Caraven SE Problem
If you had a code you could still pull it and see.
__________________
td05H turbo 16G =broke until i get more money to finish
Old 02-17-2006, 05:46 PM
The code that kept coming on before was a code for running to lean I think. I haven't seen the light come on for this issue at all.
Old 02-18-2006, 04:44 PM
yeah being fuel related could be your problem.....
__________________
Old 02-19-2006, 06:33 AM
Dodge Balls Dodge Balls is offline
I had a similar problem, but not quite the same....
My problem ended up being the electronic control system of the tranny. As it was going bad, that van showed difficulty shifting until it finally went into a safety mode and wouldn't shift out of first gear. I had to take back roads to get it to the dealer. I think it was about a $400 fix to replace the electronics. OUCH! I don't know if this is your problem, but I would recommend paying attention to any changes in the symptoms. Good luck.
__________________
If you love life, then don't waste time... for time is what life is made of.
Old 02-21-2006, 02:34 AM
emclinc emclinc is offline
Have you changed your fuel filter? Sound like a fuel shortage at the higher rpms .
__________________
aphang
Old 02-21-2006, 02:15 PM
I haven't changed the fuel filter for a while, I'll give that a shot...Thanks!
-Ryan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
