DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-21-2006, 01:44 PM
mechdude12345 mechdude12345 is offline
Default stripped hex bolt help
I striped a hex 10mm hex bolt holding the cilinder header on a 98 dodge caravan 3.0L V6 engine with a torx socket
What do I do to remove it?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-21-2006, 05:26 PM
crazymjb crazymjb is offline
Default RE: stripped hex bolt help
Im not sure what you mean by stripped the hex bolt with a torx socket? Torx is a male tool, you would have been using a "female" socket? Do you mean a 12pt socket vs. 6pt socket?
Either way, I havent been doing this stuff long enough to have picked up any techniques, but I would square it off with a dremel and use an open ended wrench to loosen it.
Mike
__________________
05 Anth/Eb Acura TL with navi
Caravan
Can't wait to join the USMC
Old 03-14-2006, 10:18 PM
BlueVanACD2005 BlueVanACD2005 is offline
If there is enough room around the bolt, you can clamp a pair of vise grip pliers to it and
try to wiggle it loose. If the head of the bolt is rounded off too much to clamp on a pair,
You can create a large bead of metal on top of the bolt head with an arc welder, and then
use the pliers on the bead to try to break the bolt loose.
Old 03-20-2006, 08:49 PM
damquick1 damquick1 is offline
go to sears and get a stripped bolt/nut remover set. It will be the best 30 dollars you'll ever spend
__________________
2006 Quad Cab THUNDER ROAD
4.7 Pure White, Satin Silver 20's
30% Tint all around, BedRug, Soft Tonneau, Vent Visors, Step Shields, Curt Reciever Hitch, and Nasta Nerf Bars.
That's all I can afford....for now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
