Sway Bar Links
Sway Bar Links
Okay, 2 nuts, top 1 and bottom 1. Replacing sounds easy enough except for northeast rust. I've got the torx socket to hold the post and 18mm wrench for the nut and i've been hitting them with penetrating oil. Pretty sure I can get the top one off. Any clues or hints on the lower onebecause there is very little or no angle to get in from behind and lower arm is in the way. Wondering if there is a trick or technique ( i personally like most of the skin ON my knuckles)? Thanks
RE: Sway Bar Links
Bad weather and no time have delayed this project. Both lower ends of links (right an left side) are broken. Does anyone have a trick for getting the nut off the broken end. My problem is holding the ball to keep it from spinning while i try to loosen the rusty nut. Please , please, please, somebody else must've had this problem too...
RE: Sway Bar Links
Thank You for your reply Ted. Mine are actually broken on both sides where they connect to the sway bar. You answered my question, I actually figured i was going to have to cut them off. Uppers, I think i might be able to unbolt as I've been spraying them with penetrant for a few weeks. NY winter salt makes so many bolts difficult to get off..... Thanks again
