DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-04-2006, 05:42 PM
blb blb is offline
Default 2000 dodge grand caravan stalling problem
I have a 2000 dodge caravan that has started stalling when coming to a stop, or when making a turn. this is becoming dangerous! i can restart it right away..but when it looses power in mid-turn...it is NOT good. this only happens in warm weather...it started last summer, stopped over the winter, and has now started again. been 'hooked-up' to the diagnostic computer and they can find no problems. any ideas??????
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-05-2006, 01:27 AM
floorslayer1 floorslayer1 is offline
Default RE: 2000 dodge grand caravan stalling problem
I had this problem with my 94 and 97 and it was the EGR valve each time, but it usually set a code and the MIL light. I could restart it easily after turning the key completely off then back on( MIL light would usually be off after this key sequence). If it is EGR you should have a code. I know what you mean about it being dangerous. Each time i'd start riding the brake and keeping RPM's up to keep it from stalling. Good Luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Old 06-05-2006, 03:16 AM
DodgeRam318_4bbl DodgeRam318_4bbl is offline
Send a message via ICQ to DodgeRam318_4bbl Send a message via AIM to DodgeRam318_4bbl Send a message via Yahoo to DodgeRam318_4bbl
Is it maybe a vaccum leak?
__________________
-John-
"I reject your reality and substitute my own."
1984 D150/318/Edelbrock Carb & Intake/TCI Sizzler/0-60 In 7.0 Seconds/Now For Sale/$3,000
Touch My Truck, You Meet Jesus. Personally.
[sm=patriot.gif]
Support Our Troops
Old 06-13-2006, 02:10 AM
zgam10 zgam10 is offline
I live in Oklahoma and have a 1996 Dodge Grand Caravan that is exhibiting the exact same problem as you described. The problem only manifests itself when the temperature is 85+. The vehicle starts right up, idles around 7-9 RPM, tends to stall, hesitate, die at slow speeds turning a corner. Although less frequent, it will also hesitate, miss, nearly die at freeway speeds. Every single time it dies, I can start it immediately back up. Once cooler weather hits, the van runs just fine.
I have read forums and articles discussing possible vapor lock, but I don't have to wait for the engine to cool down before I can restart the vehicle. I also read an article suggesting it was possibly the throttle body needing cleaning, but I didn't have the symptoms associated with that problem either. Like you, I have had the Van in the dealer's shop a couple of times. Each time, they kept the Van for about a week - waiting for an error code, which never happens. I had altered my driving habits to insure I didn't get T-boned when pulling my vehicle out in heavy traffic, but now I am giving the minivan to some friends with young kids and I want to get this problem fixed before they take ownership.
It stinks that the dealer doesn't have a clue what's happening.
Old 06-27-2006, 07:28 PM
Donnie B Donnie B is offline
I have a 97 caravan 3.3. I've been having the same problem for over a year. Will usually not stall till after 20 or 30 minutes of driving,gets worse in hot weather & harder to start back up.have replaced 02 sensor,pcm.vss.,crank sensor,catalytic converter,rebuilt motor,fuel pump 2yrs ago.still stalling & no codes & no vacuum leaks.Its driving me crazy! I'm thinking it might be the fuel pump-the one I put in was the cheap one from auto zone.does anyone have any advice before I spend 200.00 on another pump.If this don't work i'm going to try my 30.06 on it. I'll let you know which one works!
Old 07-01-2006, 06:37 AM
rabtrfld rabtrfld is offline
Is there an oil pressure lockout? Oil pressure can fall when decelerating at hi temp.
Old 07-02-2006, 02:12 PM
REPLACED FUEL PUMP & FILTER.STILL STALLING.DOES IT AT ALL SPEEDS-DON'T THINK ITS AN OIL PRESSURE PROBLEM.CODES FOR O/2 & MAP SENSORS ON.HAVE REPLACED THESE.GOING TO CHECK FOR SHORTS IN WIRING.
Old 09-26-2007, 01:44 PM
shogan shogan is offline
Ok I had this same problem on 2002 caravan. Did tune up stuff etc, no fix, took it to dealer (thinking theywould be the authority)they said I needed new wiring harness THAT WILL BE$2700HAH!. I have the diagnostic sheet with the bid on it and wish someone at Chrysler would call me to discuss it.
Found a guy who use to work for dealer. I said via the phone my van is stalling and he finished the statement when you are coming to a stop or in traffic. I said yes. He said you need your throttle body cleaned. He cleaned it 40 dollars and now it worksawesome it's been 45 days and NO re-occurence.
I hadalso noticed a flutter very occasionally when driving he said it's probably the down stream oxyegen sensor as they get carbon on them. We have not replaced yet as it's not a bigissue.
Bottom line get the throttle body cleaned.
Tags
1996, 2000, 2002, 33, car, caravan, deceleration, dodge, egr, grand, intrepid, problems, stall, stalling, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
