RE: How to know if correct fluid is in trans?
I would flush it with ATF+4 and then you know for sure what you have in it. I favor the remove pan (no drain plug), change filter, reseal pan with gasket, open the return line from the cooler, replace with clear hose, into gal jug, then fill the pan, start the car & go into neutral (done by assistant), adding fluid through the filler tube as it is drained out, until it runs clear red through the tube, shut down and replace the tranny line, start up and check for leaks method. That may take more than 4 quarts so have an extra empty gal jug and fluid handy. This was from memory and I may have omitted a step or three. Please search and read other descriptions of the process and don't take that wordy sentence as gospel. I'm just weighing in. You could install a drain plug to make the next change easier while having the pan off. I wouldn't do the change and then re-change a few days later, because there will still be 1/4-1/3 capacity of unknown fluid in the tranny. The full flush removes all the unknown fluid and replaces it with the best fluid. I would also add an aftermarket tranny cooler (bigger is better). These trannies are heat sensitive and it's just cheap insurance. Good luck with your project.
