RE: 2001 GC Sport AC issue
Sounds like the HVAC controller needs to be checked and maybe re-set. I'm not sure on a 2001, but on your (heater) controll panel try pushing the upper Left and lower Left buttons (which on mine are a rear wiper button and defrost) hold them down for a few seconds until lights start to flash and then let it go through it's self-diagnostic(which takes a minute or so). Have key on (motor not running) and fan blower set to high. You will hear and feel it opening and closing the various vent doors and such. When it is done if there is a problem, it may blink out a code using the led's. The combination of buttons you need to push may vary, but you should be able to get it to do a self test ( after which, the system may reset and work fine which it did on mine) Does anyone know if there is a different or specific combination of buttons for a 2001? Good luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
