DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-12-2006, 10:10 PM
rube740 rube740 is offline
Default Cold air from the bottom
Hello everyone, I am a proud owner of a 2001 Dodge caravan se 4 cyl. My van throws out hot air but not all over. Right under the passengers feet will come out ice cold air like if its coming from outside. What can this be? And also when I turn on the AC, there is water dripping all over the passenger side floor soaking it!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Caravan 4 cyl
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-20-2007, 06:45 PM
ahchi ahchi is offline
Default RE: Cold air from the bottom
I have same problem with my Grand caravan 2005 SE, I noticed that my feet were getting progressively colder, even with the heat on high. pouring out of a vent on the floor, but next to it where the center console is, warm air is coming. It is impossible to drive when the temperature is lower than -10. I got dealers to check 5 times already. all they said is nothing wrong with it.
Could any one help?
Old 02-22-2007, 11:18 AM
vangonebuy vangonebuy is offline
My 97 GC had a similar problem. Cold Air rushed in.
Try looking into this.
Under the glove box, there is an accuator for the heat/vent. A small black motor with a sliding control.
Simple to get to if on your back laying on the passenger side floor. (not too comfortable)
On mine the motor didnt properly turn the control. Like the pin was stripped. But the motor worked fine.
While on your back. Play with the vent direction control on the center console with the fan on.
You can tell if it is opening and closing properly. And sealing.
As for the water, I never had a problem, But I've read that they can be caused by damaged or clogged
drain lines from the wiper tray inside the engine compartment.
I dont know where the drains are for the A/C condenser.
Not sure how this will translate into an O5GC.
Good Luck.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
