DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-13-2006, 09:02 PM
kam1996 kam1996 is offline
Default Other than an overhaul, is there any other fix for oil burning/smoking engine..97 caravan 100K miles
Hey guys:
My 1997 Caravan is going for a timing belt/water pump replacment in 2 days.
I have been noticing that the engine has been buring as much as 2 quarts of oil per 3500 miles.
Today, I saw my wife drive away and the tail pipe had visible blue smoke, not enough for a cloud, but it was there.
Is there a way to slow down, what I consider, to be engine death.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-14-2006, 07:41 PM
floorslayer1 floorslayer1 is offline
Default RE: Other than an overhaul, is there any other fix for oil burning/smoking engine..97 caravan 100K miles
I would say that 2 qts in 3500 miles would be very acceptible to me for a motor with 100k. Junkyards don't consider 1qt in 1000miles excessive. Unless you're experiencing huge clouds of smoke or major power loss, i'd just keep up maintenance and go. There are some engine restore products available at NAPA and the like that you use at oil changes that are supposed to decrease smoking and increase power. Good luck.
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Old 09-18-2006, 02:21 AM
Goofy173 Goofy173 is offline
I don't know if this pertains to your engine. The 3.0 Mitsubishi engines used in 91 and other years around them had problems with valve seals going bad. If they had not slipped down into the cylinders at all, they can be removed and replaced from the top. Otherwise the heads will have to be pulled. I didn't want to tackle this so I took it to my main mechanic and he was familiar with the procedure. It only cost me around $300. If he had had to pull the heads, it would have been a lot more. This took care of my oil burning. Now if I could stop the leak...
__________________
91 Caravan 3.0 151k
Old 09-23-2006, 01:48 PM
96grandcaravan 96grandcaravan is offline
i got a 1996 dodge grand caravan that uses half a quart of mobil 1 every 8,000 miles, and my van has over 242,400 miles on it and still running strong. best vans that i ever bought. i use it to haul newspapers almost 200 miles a night. and my fuel pump just went out this morning.
Old 09-27-2006, 04:18 AM
minivanin minivanin is offline
yeah yours is prolly the 3.3, they will run forever
the 3.0s, well they suck, their valve seal design is junk, & they have been known to start going bad at 30K
-greg
__________________
Old 09-27-2006, 06:48 AM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
Quote:
ORIGINAL: minivanin
-greg
Ditto on the 3.0. In our family we have about... 3 of these. Well, had 3, now we have 2 (the others sitting in the garage). One ('88 Voyager) would use a quart of oil every 300-400 miles (blue smoke every time it takes off, new valve stem seals temporarily fixed that, but the oil burning problem is back, just not near as bad). The other ('92 LeBaron) doesn't get driven much, but its getting worse. Both have over 130,000 miles.
My grandpa rebuilt the one thats sitting in the garage floor (it was rebuilt with around 140,000 miles, and had about 290,000 miles on it [150,000 new miles] when the tranny went out, and we junked the van, kept the motor), and didn't seem to use much oil. It came out of a '90 Caravan.
I would guess if you have it rebuilt, and rebuild it with good parts, you should be able to get some good miles.
We had good luck with our rebuilt 3.0L .
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
