RE: Transmission stuck in 2nd ?? Dodge caravan 96
You arte in the dreaded limp home mode If you look in this form you will find a ton about it
The tranny is meant to do this if it finds a problem.
The first thing to check is the tranny fluid level after that you better go to the dealer or a GOOD tranny shop and have the Transmissoion codes read you can not get the codes from the check engine light it has to have a ODB2 readed put on it
Hope this helps
T
