RE: Water leaking, passenger footwell 97 GC
Leanne,
The firewall drain hose is probably pluged up. If you open the hood and look at the firewall on the passengers side you should see a black hose running down. The hose is connected with a friction connector. Pull the hose off and you'll probably see all of the water drain out. Blow out the hose and reconnect it and your problem should go away.
