DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 10-28-2006, 01:15 AM
bluer101 bluer101 is offline
Default RE: Power sliding door issue... help!!
You may have not tightened the gas cap enough on fillup.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-01-2006, 03:53 PM
aboss aboss is offline
Did you getthe door working, i am having the same problem, i am going to try the cable swap. 1 door works and the other doesnt. does anyone have the part # and the cost of the harness?
Old 11-03-2006, 07:19 PM
ForistellDodge ForistellDodge is offline
Quote:
ORIGINAL: aboss
No, haven't gone further with it. Except that at first, it closed automatically, but now it stopped doing that as well. It stops at the same point, whether opening or closing. Keep us posted on your progress.
__________________
Don't sweat the petty things; don't pet the sweaty things.
Old 11-22-2006, 03:43 AM
Zimco Zimco is offline
Hi,
I am having the exact same problem with the exact same vehicle.
Have you the thin cable wire below the gear that operates the door?
It seems that this cable changes orientation as the door turns to latch perhaps signaling the motor to turn off. It could be that the motor is simply turning off to soon. It seems unlikely to be a bad electrical wire as the problem is not intermitent or effected by moving the wire.Hopfully I will have time to explore this weekend
Quote:
ORIGINAL: ForistellDodge
Quote:
ORIGINAL: aboss
Old 02-20-2007, 07:04 PM
Finally got it to the dealer yesterday. It turned out to be that door harness mentioned here previously. Bummer.
__________________
Old 05-24-2007, 03:28 AM
chad00769 chad00769 is offline
I have a 2005 Dodge Grand Caravan Special Edition. The passenger side sliding door opened to a certain point and then stopped the same plave everytime. Just with in the past day it totally stopped working, it makes the unlocking sound when I hit the button on my key chain, but that's it. I've seen that the wiring harness could be the problem, but does anybody know where i can get one? I've looked everywhere on the net and can't find anything!!!! If anybody knows, or have any suggestions let me know!!! Thanks!
Old 05-30-2007, 04:52 PM
weigojmi weigojmi is offline
I too am having the exact same problem with the exact same car. So this is no fluke.
Can you tell us how much that part cost? Did you consider doing it yourself? I have an ESP but with a $100 deductible.
Old 06-16-2007, 02:28 AM
Sorry this took a while to respond, I haven't checked in in a while. The part cost about $135.00 and to everyone else, YES, that's definitely the problem.
__________________
Old 06-24-2007, 01:06 PM
Took mine in and yes its the wiring harness but my extended plan won't cover it. Dealer wanted $300 to fix it but I talked them down to $200. Still not sure if its even worth $65 labor...can anyone who has replaced this themselves offer any replacement instructions? Thanks.
Old 06-26-2008, 10:46 PM
joetho joetho is offline
I have a 2005 ext and the passenger power sliding door intermittently started to stop when the door openedapproximately 6". I would then manually open the door therest of the way. Then when closing the door via power it would stop about 6" from close. I went to the dealer with an estimate of $750 to replace the wire harness and motor. When I asked which was the problem the harness or motor I got the "deer in the headlights" and was told both. Not believing them I decided to do some of my own diagnosing. I do have an advantage when dealing with automotive electrical systems because I installed remote starters and alarms for 10 years. Little pat on the back there. It seemed to definitely be some kind of electrical issue. I couldbelieve the motor if there were some kind of limit switch but the problem acts just like typical door harness circuits whena wire fatigues because of repetitive bending. This problem could be diagnosed easily two ways.
1. Swap passenger side for driver side harnesses and see if it worked
2. Use multimeter to test continuity between the ends of the harness.
I opted for number 2 because I didn't want to tear our two harnesses which isn't that difficult but I am lazy. Disconnect the battery. I proceeded to unplug the harness on the car side which is behind plastic panel attached to the pillar between the front seat area and back sear area. I then unplugged the harness on the motor/door side. Put your meter on ohms or continuity and test between both ends of the plugs all wires for continuity. Slide the door shut and open for each wire. There were approximately 8 or 9 wires in the plug as I remember. Most of the wires were smaller and there were 2-3 that were larger gage. The wire that was broke in my circuit was a larger gauge solid black wire. approx. 14gauge. I carefully removed the harness the rest of the way from the car to work on my bench.
The flexible conduit is fastened with "christmas" style pins to the uni body sheet-metal so just pry up. If you don't have a "panel popper" use a pair of wire cutters to pry them up. To disengage it from the door. There is a little black plastic plug/pin thing. Pull it back and push down. Here is where you need to be meticulous if you want to replace the one bad wire. Carefully with a razor blade cut away all tape. Before you do this mark with a paint marker on the harness and special wire protectors where tape started and stopped. This way you can get the harness to lay back in the van correctly. I started by figuring out how to pull apart the special electrical plugs so I could use the ends and completely replace the wire. Just stop here. I got them apart but the problem was the special crimp ends were crimped down so much I started to ruin the end trying to get them off. So just don't do it. You will never find someone who can sellyou these special ends. Instead back up from the plug ends about 2-3" and cut the wire. Use the bad wire to pull a new wire through the flexible wire loom. I was definitely able to see a break in the wire. I almost wasn't able to pull the wire through because of it and got lucky. Don't panic. If it breaks just take your time and some tweezers and get it run through. Solder the new wire to the old ends. Make sure your new wire is cut exactly the same as the old. Add the length of the wire coating you stripped off each end of the plugs though. This way the harness will role and move in the track the way it was intended. Carefully using all of your paint marks realign all of the special looms and tape up. Reinstall and it should work. I suggest taking pictures of the harness in case you get confused putting it back together. Or look at the other side. Good luck. It really only took me about an hour or two to do.
Tags
2005, cable, caravan, chrysler, dodge, door, doors, electric, latch, power, replace, side, sliding, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
