DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
  #21
Old 08-17-2008, 07:47 PM
silvercoupe97's Avatar
silvercoupe97 silvercoupe97 is offline
Uber Moderator
Dodge Forum Moderator
Vehicle: 1997 Avenger ES
Joe, this is a good write-up! I haven't tried it since I just had the dealership find and fix it. I knew there were issues like this, but couldn't take the time from school to find it....now I know.
I think this is going to be and will continue to be an issue, so I will stick the thread to allow it to be easily found, although the search feature works too.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Thanks,
John
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 08-22-2008, 11:04 AM
gburn07 gburn07 is offline
Junior Member
Those Cat. Converters are nothing but a pain no matter what vehicle you have...I would say for how old the vehicle is (not old assuming) you just have a fidgety Cat converter. I would not worry too much about that.
  #23
Old 08-22-2008, 05:13 PM
Uber Moderator
Quote:
Umm, this thread is about the sliding door, not the catalytic converter, bro. I think you have posted in the wrong thread.
__________________
Thanks,
John
  #24
Old 09-07-2008, 07:44 PM
ImmortalMonkey ImmortalMonkey is offline
New Member
Default Electrical diagram needed
Hey all,
New user and first post.
My wife's 2003 Caravan has a passenger side power sliding door, this vehicle is actually a Braun Entervan with a lowered floor, ramp, hand controls and kneeling system. She has to use the power sliding door extensively and as you can imaging this heavy usage and the fact we live in Maine where the cold does numbers on the wiring insulation as it moves back and forth in the track, causes one or more wire breaks a year.
Thank goodness I am pretty mechanically inclined so I can make repairs on the wiring harness myself but todays break has me stumped. I made one fix on a break and fixed two other possible weak ones but the door still stops half way through the open or close motion. It still acts like a broken wire but I can't find it.
On to the real question: Does anyone have a wiring diagram of the power door system they can share with me? This would help me identify the wire to the door motor so I can narrow my search down.
Thank you,
Paul.
  #25
Old 09-11-2008, 11:46 PM
Doc Holliday1863 Doc Holliday1863 is offline
Vehicle: 2005 Dodge Grand Caravan
Default I have the same problem
I just developed this same problem on my 2005 Dodge Grand Caravan within the past week my right side passenger stops within ten inches of closeing but lucky for me i still have warrenty left so i intend to call my dodge dealer Tommorow.
Once i find out the problem and get mine repaired i'll come back and make anouther post.
  #26
Old 09-12-2008, 12:05 AM
eaglestorm eaglestorm is offline
after you have fixed all the wires there is also a flash for some door controllers
  #27
Old 09-12-2008, 12:18 AM
Uber Moderator
Don't forget to get your BCM computer updated with the most recent firmware. Without it, it may cause your door locks to stop responding without resetting the BCM.
As for your door, it's most likely the wiring that runs along the opening at the bottom of the door (vehicle side). The wiring is just an error waiting to happen. You probably have a broken wire or two just like the rest of us had. lol You're lucky yours is still under warranty. Mine messed up shortly after.
__________________
Thanks,
John
  #28
Old 10-24-2008, 06:13 PM
Simman Simman is offline
Default Repairing Power Sliding Door Cable
Joe,
Thank you very much for the very nice write up. I followed it exactly and it worked well. Before starting the work, I made sure I the 14 gauge wire, shrink wrap tubing and soldering iron. The work was a piece of cake but would've helped if I had the trim plug remover.
  #29
Old 11-02-2008, 12:33 PM
Mike K Mike K is offline
My son has a problem when the door closes (2005 Grand Caravan). Seems to want to close, but the motor clicks several times and will not close. Seems like the door travel is off. My understanding is that the door will close manually. Is this the same issue? I think it may be an adjustment, but I can't see how to give the door a little less travel. Any ideas?
Mike
__________________
Mike
  #30
Old 11-02-2008, 10:52 PM
Quote:
Mike
There are software update for power door problems make sure you are up to date before you make any adjustments
Tags
2005, cable, caravan, chrysler, dodge, door, doors, electric, latch, power, replace, side, sliding, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
