up date on head job
up date on head job
https://dodgeforum.com/m_599864/tm.htm
After all was back together another compression test showed #1 cly to be low @ 70lbs.
Leak test showed #1 Ex. not sealing. Found a stuck Hyd.Adj. on the Ex. valve.
Problem solved. Thanks to all I needed to learn[sm=itsok.gif]
On edit
BTW, Problem with CEL and PO300 still shows it ugly face even if the 3.0 run's fine.[sm=headbang.gif]
On edit
RE: up date on head job
http://www.allpar.com/forums/index.php?showtopic=85687
This Forum has been a big help and wounder if any one has any other ideals.
I just not sure about the Hyd. Adj. sticking theory and oil pump.
