Smell when defroster on..
Hello all..new to this forum
I have a 2000 Dodge caravan SE..recently, whenever I turn the defroster on with heat or without I get an eye watering, almost "smoky" smell from the vents. This only happens with the setting on defrost, I can have it on vent or floor vents and the smell is not detectable..strongest when the heat is cranked. Wondering if it may be a problem with the hoses or the radiator. Kinda wary to keep the defrost setting on as the fumes stink up the car and travel alot with two young kids in tow..Winter is coming and I live in the Northeast...Defroster is a basic necessity..
Any ideas about what this might be would be helpful. Wary of taking it to a mechanic as I might be told anything in order to get work done.
Have given thought to flushing out coolant system and replacing radiator cap...
Thanks...
Thanks...
RE: Smell when defroster on..
if the heater core was leaking
on the defrost setting the windshield would fog up from the moist air
? any exhaust leak(rich exhaust smell entering through the fresh air intake)
front exhaust pipe donut may leak in drive from the torque/flex in the motor and/or mounts
