I need your help? 1997 Grand Caravan Sport
Hello!! When I start it in the morning it takes around 7 seconds to start, after warm its quick. Now when I first start van in morning, I have a very nasty smell of Gas. What could it be?? Its not stalling or anything and everything else running great, but the smell of Gas its a very big concern. I no nothing about mechanic work.. please help with any advices, before I go to a mechanic and he takes me for a fool.
Also!! Nice to be in this forum!!
RE: I need your help? 1997 Grand Caravan Sport
check fuel pump ! you can have a leak, because you ar loosing preasure, that's way it take long time to start in the morning, it take a long time to loose the preasure, that way you have no problem to start the engine afte the first time. Look for a gas leak.
Good luck. I hope it help you!
The owner of the Van before me, is a mechanic and he says he replaced pump over 6 months ago. So it could be that its now leaking... at least you are giving me one option and this way the mechanic tomorrow can just charge me like $$$millions of dollars.. I am scared of mechanics by the way.. lol
when was the last tune-up?
plugs and wires
fuel filter/air filter/pcv
all these play in hard starting
a clogged fuel filter will reduce flow and pressure
bad plugs and wire's reduce ignition's spark(energy)
clogged air fliter reduce's air and may cause a rich condition in fuel/air mix
plugs and wires
Trending Topics
Just had full transmission service done and oil change. The other things, per last owner it was 5 months ago.
ORIGINAL: mazdab2600
plugs and wires
plugs and wires
