DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-16-2006, 01:13 PM
Cliffdodge Cliffdodge is offline
Default rear disk brake conversion
Are there any rear disk brake conversion kits? I have 2000 Grand Caravan 3.8.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-03-2007, 02:47 AM
Default RE: rear disk brake conversion
Ok! Can I use rear disk brake from the current model to fit my 2000 GC?
Old 01-04-2007, 01:17 AM
Jetmeck Jetmeck is offline
Probably can but why. Only about 25% of your braking happens out back. Don't you think that drums can handle that easily ?
Unless your just doing this for looks cause you slammed it with 22's ? If that's
the case your on your own.
Old 01-04-2007, 08:34 PM
The main reason is the stopping distance. I drove a rental GC that have the 4 wheel disc brakes and it stops better than mine. The sad this is that I only have less than 2000 miles on the brakes.
Cliff
Old 01-05-2007, 06:56 AM
Those rear discs and I'll repeat this are not helping the stopping distance. Drum brakes were on the rear of vehicles for what 30+ years after front discs were installed on factory cars. You know why they are on the rear of most cars know ? The costs came down to where a rear disc setup is cheaper than the drums. The drums out back always could and still can do as much braking as
the rear disc. ONLY 25% of your braking is done out back on your average vehicle.
The advantage would be on higher horsepower sports for repeatability as the discs would obviously cool better than the drums.
You want better brakes, tune them up so to speak. Performance pads bedded properly will do wonders along with turning the rotors.
The rear drum brakes on the Caravan already has two long shoes in the back
which work very well.
Old 01-05-2007, 07:00 AM
I want you to understand what I meant. Up front there is absolutely no doubt discs are the way to go because the front brakes get FULL pressure from the brake system. If the rears got full full pressure you would lock up your tires or the ABS would kick in all the time and it would be unsafe to drive.So the factory reduced the rear pressure to approximately 25% of what the front gets and that is why rear discs are not needed.
Old 01-29-2007, 11:58 AM
newday newday is offline
Quote:
ORIGINAL: Jetmeck
You are an ignorant ASS!
Disc brakes are better than drums no matter what purpose
the vehicle serves. who are you to try discouraging anyone
from doing what they want to their vehicle?
Obviously you are, but not all ofus can be
content with just good enough.
Man! you are a leading jackass
Old 01-29-2007, 12:03 PM
Quote:
ORIGINAL: Cliffdodge
I don't see why the disc stub axle would not bolt on in place of the drum. If anything, see if you can find a complete rear axle.
you should also check if you can use your current MC.
Old 01-30-2007, 05:56 PM
Newday,
You clearly don't have any mechanical background or experience do you ?
Just because you read something on the net your an expert. Go ahead waste your time putting rear disks on a minivan and we'll laugh ourselves silly at your dumbass. MOE-RON
PS...Why don't you put NOS on there too
Old 04-21-2008, 11:59 PM
lilyjohnalexs lilyjohnalexs is offline
I'M sorry i just have to comment on this since "jetmeck" obviously doesn't have any mechanical background either since a vehicle has abs on it that vehicles brake system works all together and all brake are equally positioned at 25% breaking power since the the vehicle doesn't lunge forward in braking. thus disks would be more efficient
Tags
conversion, disk, dodge, kits, ram, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
