RE: 98 dodge grandcaravan
Most filter kits come with a new gasket. Chrysler uses RTV when they do it, but i've never had a problem with the gaskets that come with the kits. Make sure you use atf+4 when you do it. It is simple to do and all you need is a 10mm socket and short extension to get out the 14 or 15 bolts in the pan and a bunch of rags to wipe the fluid off your arms lol.
As for the knock, I'd look into sway bar links and bushings first. Then strut bearing plates and then ball joints. Good luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
