DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-27-2006, 11:45 PM
daimler_ch5 daimler_ch5 is offline
Default need help, speedo and tach gone.
my friend recently called me for help. it seems that his speedometer and tachometer have just failed in his chrysler minivan. everything else in the cluster works fine and the van still runs and drives fine.
i was thinking possibly a fuse or an electrical connector somewhere that feeds both instruments?
i cant imagine that speedo and tach would run off of the same one sensor, more likely that speedo is off of a wheel speed sensor or a tone ring in the final drive carrier of the transaxle, and the tach off of the crank sensor, right? i wouldnt think that these would both fail at the same time, and more, if the crank sensor failed, the van shouldnt run very well if at all.
does anyone have a fuse panel diagram or a wiring diagram for the instrument cluster they could send me? i think its a 96 town and country with a 3.3
thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
alex
1995 ram 1500
1984 mercedes-benz 500sel euro
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-28-2006, 03:57 AM
brandoncrone brandoncrone is offline
Default RE: need help, speedo and tach gone.
Unhook the battery for 15 seconds. The problem is located inside the alternator. As the brushes wear, they sent voltage spikes into the PCM, which in turn sends the spike to the cluster and freezes it up. The battery disconnect will take care of it for a little while, but it will happen again. You will need to replace the alternator to correct.
__________________
Dodge/Chrysler/Jeep Technician 14 Years, ASE Master Certfied
1996 Jeep Grand Cherokee Laredo 75,600 miles
1999 Dodge Dakota Sport 318ci 135000 miles
2008 Chrysler Town and Country Limited 2500 miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
