DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-16-2009, 03:35 PM
surfit surfit is offline
I believe it is located between the fuel tank and the frame. You must drop the
fuel tank to access it (thanks, Chrysler). The good news is you only need to replace
it every 65K miles. I let the dealer replace mine as I didn't want to deal with dropping the fuel tank. It wasn't too expensive.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-04-2009, 07:01 PM
sleeplesman sleeplesman is offline
1998 Dodge Caravan
My Garage
Vehicle: 94 and 98 voyager,68 dart 270
i would start with checking for a spark at the plugs. I had issues with the plug that provided power to the coil pack on the top of my engine. a good shot of wd40 and reseated the plug 6 times. never acted up again.
Old 05-05-2009, 11:23 PM
rhino24 rhino24 is offline
i have a 2002 dodge caravan with codes saying that tps is bad ,ect bad ,a/c compressor bad , and inj 4 driver bad i think that it is the pcm is shorted any thoughts?
Old 05-06-2009, 01:32 AM
Nofrag's Avatar
Nofrag Nofrag is offline
Vehicle: 2B4GP4530TR decode it to find out ;)
At chrysler HQ they have a panel with a bunch of buttons, they push one of those buttons and a certain problem pops up in a certain percentage of a certain model line. Last week they pushed the caravan no start button, this week they pushed the caravan TPS/ECT/injector#4/ac button. lol j/k
It is funny though how so many people will get the same problem at the same time.
__________________
As a DF moderator My opinion is only my own and does not represent the DF community, it's staff, or affiliates. I moderate solely based upon guidelines and not in regards to my own personal beliefs.
Rear Wiper Club Member #2
Quote:
Originally Posted by PappiDread6 View Post
Hello My Name is Pappi Dread and I have an addiction, Male DF Members
Old 07-09-2009, 03:27 PM
shadowzkillerz shadowzkillerz is offline
Default replacement
I have a 1990 dodge caravan, I just replaced the oil pump, oil pan gasket, valve cover gasket, and ofcourse oil and filter, but I went to start my car, and it just cranks. I replaced the sparks and wires thinking that might be it, but now i think it has something to do with asd relay. Is there a fuse or do i just replace the relay. It is a 1990 caravan 2.5L non-turbo manual trans.
Old 07-09-2009, 03:29 PM
Default replacement
I have a 1990 dodge caravan, I just replaced the oil pump, oil pan gasket, valve cover gasket, and ofcourse oil and filter, but I went to start my car, and it just cranks. I replaced the sparks and wires thinking that might be it, but now i think it has something to do with asd relay. Is there a fuse or do i just replace the relay? It is a 1990 caravan 2.5L non-turbo manual trans.
Old 09-12-2009, 08:40 PM
mrusa4440 mrusa4440 is offline
PLEASE help!! I have a 2007 grand caravan (the wife's kid hauler) and I need to replace the rear brake pads. I just finished the front brakes (rotors, pads) that was like any other disk brake job, but my problem is this.. how do you remove the #%$@%#* calipers??? set up not like the front. do you remove the caliper guide pins?? and if so what do you use?? all my allen wrenches don't fit, is it a special tool?? I'm a machanic by trade ( airplanes not cars ) and this problem is killing me. I tried to buy the book but the van is too new and nobody makes one yet. THANKS in advance for anyone that can help.
OK I fixed it. Gezzz. Just in case anybody else wants to know, you use a 7MM allen wrench to remove the guide pins. As it turns out my shoe box full of allens had every metric size EXECPT 7MM. go figure.
Old 09-23-2009, 08:05 AM
greaper_ca greaper_ca is offline
Hey Nofrag,
Did you actually have this problem? I currently have it and I'm starting to think that it's my PCM.
Do you know if there is anyway to relearn the PCM without going to the dealer. I'm thinking of going to the wreckers and getting a used PCM.
Thanks
Old 10-03-2009, 12:35 AM
Singh Singh is offline
I just bought new dodge caravan 2009 my gig REN after i bought it just week after i installed u connect through same dealer mopar product. I can make & receive calls through u connect but not able too download my phone book to my gig. And some of ph. no not reconized to u connect even i repeated so many times with normal voice
Any my touch screen stop working. I don't know what happened.
Old 10-08-2009, 03:29 PM
2002ACRNEON 2002ACRNEON is offline
Quote:
Originally Posted by foxybutterflys78 View Post
where is the EGR valve on a 2005 dodge caravan?
The EGR valve on the V-6's is on top of the front cylinder head on the side with the serpentine belt. There is a metal tube/pipe that goes up and into the top of the intake manifold.
Tags
1996, 2005, 94, caravan, diy, dodge, dyi, egr, grand, location, pipe, plugs, spark, straight, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
