Dodge caravan sport panel light
RE: Dodge caravan sport panel light
That is a Check Engine Light!!! It means that you have a problem!! to know what is the problem, you have to know the code!!
Turn the key to on position (without start the engine) three times and leave it on (on-off-on-off-on). The check engine wil start blinking giving you the code. the fist code will be 2-1 ( first 50 starts after disconect the battery) ok. then other code will appears and the last code will be 5-5 ( ending) ok
check the code!
check the code!
