Engine light
RE: Engine light
It means that you have a problem!! to know what is the problem, you have to know the code!!
Turn the key toON position (without start the engine) three times and leave it ON (ON-OFF-ON-OFF-ON). The check engine wil start blinking giving you the code. the fist code will be 2-1 ( first 50 starts after disconect the battery) ok. then other code will appears and the last code will be 5-5 ( ending) ok
check the code!
check the code!
RE: Engine light
Invest in an OBDII code reader. You can get them for less than $100, and they work on all cars from 1996 up. It will tell you the code, and then you can match the code up with the malfunction in the included booklet (or at any of the 1000's of OBD code websites)
If you do not want to buy one, I would suggest taking it to the local auto zone. They will scan your code and tell you what it means free of charge.
