DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-13-2007, 08:50 PM
korupt98 korupt98 is offline
Default 1997 Dodge Caravan Stalls when turning after stop
I have a 97 dodge caravan and it stalls whenever I try to make a complete turn at a traffic light. If I am going straight it is not a problem and if I take a wide turn there is no problem. However, if I try to make a u-turn it will stall in the middle of the road. It appears to happen more frequently when the engine is warm but I am not sure.
I can reproduce the problem by turning the wheel all the way while parked. It would start and automatically stall once when the wheel was in a locked position. I had to move the wheel around a little before it started.
I took it in and no errors are showing up on the diagnostics.
Thank you for your help.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-29-2007, 09:01 PM
vangonebuy vangonebuy is offline
Default RE: 1997 Dodge Caravan Stalls when turning after stop
Bet it runs great, most of the time also.?.
I would start with a can of throttle body cleaner.
Carefully follow the instructions. and spray the inside of the carburator repeatedly.
You will see black deposits through into the manifold. Do the best you can A cleaning carefully with a Qtip helps.
It may sound crazy, But I had the same problem and it helped completely.
Good Luck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
