DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-20-2007, 09:05 PM
BGratil BGratil is offline
Default problem on door lock
Hello, I have a problem with my Dodge Grand Caravan. when I tried to lock it or open it using the one on door (driver side) is not working,
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-05-2007, 03:16 PM
dg98adams dg98adams is offline
Default RE: problem on door lock
You probably have a broken lock actuator rod clip. Available from the dealer or the HELP section of autoparts store, $3-4 BUCKS.
If you pull the door panel, and look inside you may find a loose 1/2 rod that connects the key lock to the lock mechanism.
These aren't hard to replace. Push the clip into the mechanism, slide rod thru the hole and rotate the clip up onto the rod.
It's harder to explain than to just look at it.
DG
Old 06-06-2007, 02:22 AM
next2pool next2pool is offline
These lock assemblies are a unitized design and many times the whole unit has to be replaced. If it isn't obvoius that a link is loose, it may be the lock asm. They are very pricey new (about $75, but can be had at a pick & pull for $10. It is a very easy R&R if it comes to that
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
