next page
if the cam\s are out one tooth the valves will be opening and closeing at the wrong time and the engine will run rough
look for the marks on the gears when it's together before the covers are back on turn the crankshaft bolt with a socket 1 full turn then double check your marks
its a pain to have to pull it apart again if your off
http://www.autozone.com/servlet/UiBr...3d801a3ccc.jsp
