Charger randomly shuts off
Old 06-16-2013, 10:29 AM
dodgedvl's Avatar
dodgedvl
dodgedvl is offline
i dont know if this will help any of you,but my experience with the same issue i was having like you are. the dealer changed the PCM unit and it works just fine now, with no shutting down issues. good luck to you all.
Old 04-26-2021, 08:06 AM
Paul Robs's Avatar
Paul Robs
Paul Robs is offline
Default How do you know if that’s the problem?
Originally Posted by master tech
I have found out the problem maybe either the coil packs or the wrong spark plugs. Or both. I have ran into this problem on some of our 2006 thru 2008 hemi's.
my 06 hemi is doing the same thing and I did everything you can do possible and nothing has worked
Quick Reply: Charger randomly shuts off
