a/c blend door how to access
07 charger sxt
air is cold coming out of driver side vent. only warm coming out of passenger vent. i don't have dual a/c system or digital readout.
if a blend door problem, can you tell me how to get access to the door so that i can jam it to stay open with something. i can't pay to have the whole dash removed. how can i get access or can i put my hands on the shaft that turns the door open and closed. i saw a couple of white tabs on passenger side by glove compartment that appears to hide maybe the end of a hinge. maybe take the caps off???
07 charger sxt
Don't know if blend air door problem or not but here is the blend air door info you asked about.
1.
Disconnect and isolate the negative battery cable.
2.
Remove the instrument panel silencer from the driver side of the instrument panel .
3.
Remove the three screws (1) that secure the blend door actuator (2) to the driver side of the HVAC air distribution housing (3).
4.
Remove the blend door actuator from the air distribution housing and disconnect the HVAC wire harness connector (4) and remove the actuator from the vehicle.
Thank you for the response. It believe the actuator is functioning. i found it the other day.
I was trying to find out how to get access to the blend door so see if the axle that moves the blend door is broken. I wanted to grab hold of the blend door. i know it is the housing unit and to see it i would have to remove the dash. I was hoping to get access to the end of the axle of the blend door in order to turn it manually.
Can you give me some assistance?
Trending Topics
With the blower control **** in the off position start the vehicle. Depress the defrost button and hold while then turning the blower control **** to high. The defrost led should flash during the blend door actuation calibration process. The entire process takes approximately 90 seconds.
