Climate control problems
Old 05-28-2014, 09:57 AM
Hoaxie's Avatar
Hoaxie
Hoaxie is offline
Default Climate control problems
Need help please. I have a 2007 charger that has a climate control problem. It suddenly stopped working. I've checked all the mini fuses front and back. I'm pretty sure it is not the control itself. I have no doc voltage to the harness at the control. I've put an idiot light at the number 14 fuse in the back and it does not light up.it is a 10 amp fuse so that is the correct one. I am pretty good with a meter so this should have been a no brainier......please help.
Old 05-28-2014, 10:05 AM
Hoaxie's Avatar
Hoaxie
Hoaxie is offline
I almost forgot the passenger side up airbag light on the dash is also on. I'm not sure if this is relieve nor not to this same issue. Thanks for any info.
Old 05-29-2014, 02:54 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Are there any fault codes?
Old 06-03-2014, 07:18 PM
ohkwehonwe's Avatar
ohkwehonwe
ohkwehonwe is offline
im having same prob on a 08 charger please let me know if you find problem and like wise thanks
Old 06-04-2014, 08:57 PM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
HemiMoparGuy1981 is offline
If your test light didn't light up, then either you forgot to turn the key to On, or you have no voltage at the fuse, so obviously no voltage will get through that fuse and to the control module itself. Without a schematic, I am unsure of where that hot lead for the fuse box is coming from, but I'd be looking towards that wire.
edit: Wasn't trying to be a wise @$$ about not having the key on, we've all done stupid things like that...I once did a timing belt and spent hours moving it one tooth ahead and behind and redoing it all again because of a no start...before I knew it was a belt, I was checking spark and fuel pressure, so I had the fuel line unhooked, and apparently never hooked it back up.....
Quick Reply: Climate control problems
