Transmission levels
Old 03-01-2015, 05:06 PM
rene0818's Avatar
rene0818
rene0818 is offline
Default Transmission levels
I've been leaking (small amount) a little bit of tranny fluid from the trans. adapter on my Charger. I had a tranny flush done on May 2014 and a few days ago during cold weather I noticed a slight slip in the morning hours, so I decided to put in about 16 oz. of fluid. When I took it to the dealership, the tech said the tranny was 28 oz low, and he replaced the adapter and refilled the trans. What is the likelihood that any damaged has been caused? The tranny is working fine, no slipping. I mean...I've had the car for two years, It hadn't slipped before and I don't know how long that small leak has been there.
Old 03-02-2015, 10:49 AM
jkeaton is offline
Dodge Forum Administrator
Why did you add only 16 oz if it was over a quart low? Did you check the level before and after adding? If the transmission is working fine now, then it's probably ok. I'd check your fluid level more often though.
Old 03-03-2015, 09:18 AM
rene0818's Avatar
rene0818
rene0818 is offline
Because it is a non serviceable transmission, and the dealer said that overfilling it could cause damage as well.
Old 03-03-2015, 09:29 AM
jkeaton is offline
Ah. Gotcha. I actually hate that. My Journey and Mustang are the same way. Can't check the #@!% transmission fluid level myself.
Old 03-03-2015, 11:08 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
You can get a dipstick for them, either B&M, Mercedes or just take a really long wire tie (thisis what I used). Problem is you need to be able to accurately measure the trans temp to bounce it off the chart in the manual. That's why they made it so you couldn't check it and had to take it to the dealer.
Old 03-04-2015, 07:17 PM
rene0818's Avatar
rene0818
rene0818 is offline
B&M sells that? or a wire? i'm gonna try that. I hate the fact that I can't check it either. thanks guys!
Old 03-09-2015, 11:51 AM
HemiLonestar
Old 03-11-2015, 07:33 PM
rene0818's Avatar
rene0818
rene0818 is offline
Default TMR Delete
What is an tmr delete?
Quick Reply: Transmission levels
