2008 Dodge Charger won't start
Old 10-31-2016, 03:10 AM
Andrew Finn's Avatar
Andrew Finn
Andrew Finn is offline
Default 2008 Dodge Charger won't start
Recently I was driving my 08 Charger 2.7L when the engine shut off and I lost all power. The car started back up when I turned the key once but when now it won't start. The radio comes on and all my dash light and headlights come on. The engine light will blink but then stays on. I took it to my local dealer and they replaced the Ignition module. After that didn't work they replaced the tipm module. That did not fix the problem. After spending over 2000 I have brought the car home and in need of help trying to figure out what is wrong with it. I have had the battery tested and it is fine. I replaced the starter relay.
Old 10-31-2016, 08:35 AM
primem's Avatar
primem
primem is offline
does it crank over or it cranks over but will not start
any dtc set
Old 10-31-2016, 12:04 PM
Andrew Finn
It will not crank over at all.
