P0300 FREEZE frame Data Available
I have codes P0300 and P0132.
2006 Dodge Charger 3.5L
The car sputters at low and medium speeds.
The car losses acceleration temporarily and then kicks in at low to medium speeds.
The problem was once in a while. Now it's 3 days in a row.
Freeze Frame Information:
Parameter Description Results
DTC for which Freeze Frame was Stored P0300
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 89.02 %
Engine Coolant Temp 134.60 °F
Short Term Fuel Trim - Bank 1 -33.59 %
Long Term Fuel Trim - Bank 1 0.78 %
Short Term Fuel Trim - Bank 2 -3.13 %
Long Term Fuel Trim - Bank 2 1.56 %
Intake Manifold Absolute Pressure 26.65 inHg
Engine RPM 381.25 rpm
Vehicle Speed Sensor 9.32 mph
Ignition Timing Advance #1 Cylinder 18.00 °
Intake Air Temperature 80.60 °F
Absolute Throttle Position 29.02 %
Time Since Engine Start 180 sec
Thanks for your HELP!
O2 sensor readings the next day.
