2006 3.5 air in cooling system.
Old 01-17-2017, 08:51 AM
andy38340's Avatar
andy38340
andy38340 is offline
Default 2006 3.5 air in cooling system.
Replaced the thermostat and housing in a 2006 3.5 because it was leaking. Spent 3+ hours trying to bleed air out.
Temp gauge used to be at halfway. Now it stays at 1/4 while driving. Dips below 1/4 when you turn the heat on.
After a 30 minute ride, if you sit and idle at 1500, the gauge will go up to the halfway mark, but no further.
Is there still air in the system?
Quick Reply: 2006 3.5 air in cooling system.
